Varying MCU clock speed - the easy way
Has thanked: 167 times
Been thanked: 975 times
Post by mnfisher »
I was experimenting with measuring the power consumption of a PIC MCU.
I wondered how this would vary with clock speed - and there is always a trade-off with more speed needing more power...
Using a PIC16F887 - the internal clock can be set at speeds up to 8MHz - but an external clock can be up to 20MHz,
I wrote a simple blinkie - and connected a pin to a logic analyser (with a 1ms delay in the loop)
In the chip options I set clock to XC - and I connected a function generator to pin OSC1 (and ground) I added a capacitor between OSC2 and ground - but this didn't seem to be necessary. I also set clock speed as 20MHz
I set the function generator to a sine wave at 20MHz and on turning the signal on got a neat set of pulses output, I could reduce the clock speed (and even overclock 24MHz worked for a handy 20% speed boost :-) Not recommended for use in the real world though!)
Setting the clock to 10Mhz - gave a 2ms pulse as expected - and the chip was happy at alll the clock speeds I tested (down to 32kHz)
I also tested a PIC12F1840 - and the best power savings are to be had by using sleep wherever possible, a low speed clock and reducing the voltage - and the PIC was using about 300nA when sleeping ! For battery applications this is good - however other times what is needed is speed and power consumption is less of a concern...
As most (many?) oscilloscopes have a signal generator - this can be fairly easy to implement and use...
Has thanked: 458 times
Been thanked: 683 times
Re: Varying MCU clock speed - the easy way
Hi Martin
You are starting to practise Dark Arts :)
You really can get drawn into getting a chip to consume almost nothing and clocks play a big part. Many chips can be configured to run at different speeds on-the-fly so you could set your chip to sleep using a very low power and frequrency oscillator (e.g. 32KHz) then when it is time to do something more fun have the chip use a higher speed more suited to the task in hand.
Peripherals also play a part and some need a clock during sleep, which can often be accommodated. Certain Timers can be configured to use an external crystal, thereby providiing a clock during sleep.
You have ruined Christmas for me as I was planning to do some similar tests over the period to what you have done, now no need :lol:
Post by mnfisher »
It's my Christmas gift to the world.
I call it the TimeSink (Pat Pending)
Which reminds me - Wacky Races.... See how powerful it is😎
alanwms
Has thanked: 26 times
Been thanked: 8 times
Post by alanwms »
Interesting speed versus consumption. I always wonder about speed, and if the clock is correctly set. My verification is to simply flash an LED with 1 second intervals. If it isn't flashing at 1 second intervals, the clock speed setting is incorrect. Kinda verifies for me.
Post by mnfisher »
The classic blinkie. Always good - especially when approaching a new MCU.
As Iain mentioned - it is possible to alter the clock speed on the fly. We were looking at battery powered options - so low power was a primary concern.
Post by mnfisher »
And - I found a small hitch with this...
Testing a PIC 12F1840 and it was quite happy to run off the clock signal. No power needed :-) Those batteries should last and last!
