Hi to all !
I would like to set internal oscillator for PIC18F47K40 at 64MHZ. What is the config setup for stable operation at that INTOSC. ?
What is the freq. set at other options , and OSCCON, OSCFREQ ,OSCTUNE at Main as C code?
Thanks in advance.
Basil
CONFIG FOR PIC18F47K40 -44QFP
SILVESTROS
- Has thanked: 32 times
- Been thanked: 2 times
- Has thanked: 447 times
- Been thanked: 674 times
Re: CONFIG FOR PIC18F47K40 -44QFP
I'm not familiar with that chip and I can't actually test at present, however under project option you have settings for the oscillator and can set it for
HFINTOSC with HFFRQ = 64MHz (remember to set clock speed to 64MHz too).
If that doesn't do it, you could try using the Internal Oscillator Helper found under Component Libraries > Runtime. This will generate C-code to set the oscillator.
Hope this helps.
Hope this helps.
SILVESTROS
Many thanks for info..
Below is the tested config for PIC18F47K40 at 64MHZ INTERNAL OSCILLATOR
Clock speed...64MHZ
OSC. MODE...Oscillator DISABLED
DEFAULT OSC...HFINTOSC with HFFRQ=64MHZ
FCMEN (CLOCK OUT ENABLE) ... OFF
CSWEN...OFF
FCMEN (FAIL SAFE CLOCK MONITOR) ...OFF
C CODE at main for initialize oscillator
OSCFRQ=0b00001000;
Basil
Clock speed...64MHZ
CSWEN...OFF
OSCFRQ=0b00001000;
Basil
