pic 16f1788
Philc
Has thanked: 2 times
pic 16f1788
Post by Philc »
i have this problem with this program looping when it shouldn't, i have 12 leds on output B0 to B7 and C4 to C7, now when i turn them on one at a time its fine, if i then turn off all port B and then use port masking to turn off C4 to C7 the program turns off the leds but loops back and turns them all on again one at a time. The only way i can get it to work correctly is if i turn off C4 then C5 then C6 then C7 and it works perfectly. Any ideas and i also put a counter in so i could control it turn on the next level of 12 leds and that wouldn't work unless i turned C port off individually. what i am playing about with is a led tower 12 leds in rows and 12 high, like the ones off ebay but i am only using the first 2 rows until i get the hang of flowcode. Hopefully its just me but i have tried everything and cant get it to work unless port c turned off individually. I even tried turning off all port C and it still looped when i have no loops or connection point in to make it do that. By turning off i mean output 0. Thanks
Has thanked: 425 times
Been thanked: 646 times
Re: pic 16f1788
If you post your chart we can have a look. Without it we have no way of knowing what is going on.
Philc
Re: pic 16f1788
Post by Philc »
how do i attach the chart ? i have tried and cant get it to attach. thanks
Re: pic 16f1788
I you click the "Full Editor & Preview" button, you can then either drag and drop or select files to attach.
Philc
Re: pic 16f1788
Post by Philc »
i have attahed it but dont know where its gone, the bit of the code is the port c oof bit, it runs fine in the debug but doesnt on the chip unless prot c is turned off individually then its fine..
Declare Connection PointDeclare Connection Point: : B
Output:
off -> C3
Declare Connection PointDeclare Connection Point: [A]: A
Calculation:
count = count + 1
Delay:
10 ms
Output:
on -> C4
Delay:
100 ms
Output:
on -> C5
Delay:
100 ms
Output:
on -> C6
Delay:
100 ms
Output:
on -> C7
Delay:
100 ms
Output:
on -> B0
Delay:
100 ms
Output:
on -> B0
Delay:
100 ms
Output:
on -> B1
Delay:
100 ms
Output:
on -> B2
Delay:
100 ms
Output:
on -> B3
Delay:
100 ms
Output:
on -> B4
Delay:
100 ms
Output:
on -> B5
Delay:
100 ms
Output:
on -> B6
Delay:
100 ms
Output:
on -> B7
Delay:
100 ms
Output:
off -> PORTB
Output:
off & 0xF0 -> PORTC
Delay:
100 ms
Output:
off -> C2
Decision:
If count > 1 ?
<TRUE BRANCH>
Decision:
If count = 3 ?
<TRUE BRANCH>
Input:
C3 -> off
Input:
C2 -> off
Input:
C1 -> off
Delay:
10 ms
counter reset:
count = 0
Goto Connection PointGoto Connection Point: : B
</TRUE BRANCH>
<FALSE BRANCH>
Input:
C2 -> off
Delay:
10 ms
Output:
off -> C1
</FALSE BRANCH>
</TRUE BRANCH>
<FALSE BRANCH>
</FALSE BRANCH>
Goto Connection PointGoto Connection Point: [A]: A
run fine on the chip unless i turn port c off individually.. thanks
Re: pic 16f1788
When you save your chart you get a file with a .fcfx extension (for example, test.fcfx).
This is the file you need to attach. If you click on Full Editor & Preview you will see an option to attach the file (you may need to scroll down) or you can just drag-n-drop into the reply window.
We really do need to see the chart to help.
