UART don't work on a ESP32 C Super Mini Board
MJU20
Has thanked: 105 times
Been thanked: 74 times
Flowcode v10 UART don't work on a ESP32 C Super Mini Board
Post by MJU20 »
In another topic, someone asked me to test something on a different board then which I was using.
The first one I found was a ESP32 C3 Super Mini board:
When I view the booting on a serial monitor I can follow the booting of this board, but when I try and install a UART component, I get no reply
I used the UART (RS232) component and the UART software timer component.
Both don't get the UART send messages to the serial monitor.
I initialise the UART and send a string, but this is never received whatever baudrate I choose.
Any ideas? I use channel 1 and this uses the RX/TX pins like on the pic above..
Has thanked: 156 times
Been thanked: 902 times
Re: UART don't work on a ESP32 C Super Mini Board
Post by mnfisher »
Not all boards seem to have the UART connected to the USB port. Test using a usb to uart (ftdi) converter connected to d0/d1.
As the debug info is being output then it may be possible to select the same pins for one of the user channels.
MJU20
Post by MJU20 »
Thank you Martin,
I found out that the pins connected to the USB are GPIO pins 18/19.
But when I try to port the UART to these pins I can't flash my program to the device.
