Esp-idf Installation
muller54
Post by muller54 »
hello
I am really disappointed, I thought I could program esp32 with Flowcode, but it has been at least 10 times since I uninstall and reinstall esp-idf, git and python without success. I tried with python 3.7, 3.8, 3.9. with esp-idf 2.3 and 2.4. by scrupulously following the installation pdf recommended on the forum. But nothing works. When the installation takes place without error 1 or error 2. It is during compilation that I have an error. Is there a foolproof method?
Thank you
cordially
Francois
Has thanked: 88 times
Been thanked: 273 times
Re: Esp-idf Installation
Unfortunately not with Windows.
Common problems are such as spaces or non simple alpha characters in paths.
Best also to go with the suggested defaults of the Espressif installer.
Could you post the project msg.txt file? This will/might helps us identify the error.
muller54
Post by muller54 »
Thank you for your reply. I enclose the message from the compiler
Compiler Messages.txt
(3.32 KiB) Downloaded 603 times
Has thanked: 529 times
Been thanked: 719 times
Did you use your own version of python? It looks like python is missing libraries. Click, pyserial etc.
muller54
Post by muller54 »
No, it's a version of python downloaded by eps-idf
Could you try clicking the "ESP-IDF Command prompt" that is on your desktop.
Then type and run install.bat
Has thanked: 665 times
Been thanked: 744 times
In addition to Leigh's post, have you seen this post?
