xc32-gcc.exe: error: Projekte\.: No such file or directory
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Post by SpeedPIC32 »
hello benj,
Flowcode 9 has a problem. :arrow:
It does not remember any directories.
as soon as I save a working project in another directory this error message comes up.
This error message also comes when I create the project in any directory.
it cannot be that such a modern software has such a fundamental problem ...... :evil: :evil: :evil:
another mistake
In the window of the USB chip selection the information about which PIC has a USB interface is incorrect.
For example, PIC32MX470F512 has USB
Kind regards
USB Matrix_error.txt
(1.21 KiB) Downloaded 449 times
USB Matrix.txt
(5.8 KiB) Downloaded 502 times
Has thanked: 264 times
Been thanked: 424 times
Re: xc32-gcc.exe: error: Projekte\.: No such file or directory
There is a fix to Flowcode that should resolve the issue with file locations, but it's not quite ready for release yet.
In the meantime, this might fix your issue. You will need to edit this file:
C:\Program Files (x86)\Flowcode\Compilers\pic32\batch\PIC32compCDC.bat
Find the line that looks like this:
@SET MX_HEADERS=-I%MX_SRCDIR%. -I%MX_CAL_USB% -I%MX_HARMONY% -I%MX_HARMONY%\framework
And put quotes around the -I entries as follows:
@SET MX_HEADERS=-I"%MX_SRCDIR%." -I"%MX_CAL_USB%" -I"%MX_HARMONY%" -I"%MX_HARMONY%\framework"
Please let us know if this works.
SpeedPIC32
hi, yes it works.
Isn't something like that tested by you?
I took the trouble to install and test everything on a second computer.
Kind regards
SpeedPic32
SpeedPIC32
Danke
