PIC12f510
alanwms
Has thanked: 26 times
Been thanked: 8 times
PIC12f510
Post by alanwms »
Hello:
I have the PIC12f510 program simply turning an LED on in an infinite while loop. Setup the speed for 8mhz internal osc. The program downloads, but there is no activity on the GP2 (LED connected to GP2).
There are only a few project option selections for this chip regarding oscillator. Do I have to insert c code to get the oscillator to run? I disabled my dwells just in case, but I see no activity on the io port. Attempted manual memclr reset - no luck
Simple FC10 file attached
Help appreciated - Thank you.
Test Routine.fcfx
(7.31 KiB) Downloaded 223 times
Has thanked: 435 times
Been thanked: 651 times
Re: PIC12f510
Yes you do need to include a C-block to use the internal oscillator and this should be your first block.
FC makes this easy. You will find a component called IntOsc Helper in Components>Runtime (I think). This will check settings and provide the code. Simply copy and paste into your C-Block.
Re: PIC12f510
Following on, it seems FC may have a "bug" in that the OscHelper doesn't recognise the chip.
I will dig put the datasheet to see what the register setting needs to be, but this may not be until tomorrow.
alanwms
Re: PIC12f510
Post by alanwms »
OK
alanwms
Re: PIC12f510
Post by alanwms »
It seems to me that the configuration bits can only be set upon program mode entry suggesting that I can't put a C code in the 'Main'
Those bits ARE set in the "program options" but don't seem to work. Maybe I'm doing something to hinder that - not sure.
Also - The "Download config now" in the project options is doing nothin. I thought I would try that.
Re: PIC12f510
I've not had a chance to look at the datasheet yet, hopefully later on.
Meanwhile I've attached a chart showing how to set up a PIC16F1939 to use an internal 8MHz clock. Most PICs are pretty similar but you do get the odd exception. In the chart you will see the IntOsc Helper component generating the required C-Code to use.
IntOsc_Example.fcfx
(8.74 KiB) Downloaded 219 times
alanwms
Re: PIC12f510
Post by alanwms »
Thanks for your efforts -
I don't think that the pic12f510 has an OSCCON register. From my readings, it's looking like the configuration file can only be downloaded at program time, and can't be configured in the main
Re: PIC12f510
It may not have an OSCON, the datasheet will specify the register name. My chart was really just to show the steps for "a" PIC.
Looking in the old forum I see this
https://www.flowcode.co.uk/mmforums/vie ... 510#p14659
Seems about 16 years ago the chip may have been dropped.
Has thanked: 159 times
Been thanked: 943 times
Re: PIC12f510
Post by mnfisher »
As an idea..
I don't have the particular part to try though.
Run pickit3.exe - this is microchip's (GUI) programming tool.
With the PicKit connected to the (powered) MCU - it should display PicKit3 connected - (click on Tools-Check Communication if needed) PIC Device found and above that - the part number. Click on configuration and see what is saved there (and adjust if required)
The issue is finding the download if you don't already have it (part of the MPLab studio I believe)
Can do a similar thing with the excellent (but not free - I have no affiliation) PicKitPlus.
I'll try a bit harder and find where I downloaded it from.
MArtin
Has thanked: 713 times
Been thanked: 775 times
Re: PIC12f510
As there is no output for you on A2, I was wondering why you are using osccal as that is only to adjust the osc speed above or below the centre frequency for extra precision, if the frequency is off a bit.
There are no other registers like osccon since there are only two selectable frequencies (4 & 8 MHz) from withing the configuration settings.
So no bug within internal oscillator component.
As you got master clear enable bit to enabled, it will be worth measuring the voltage across pin 4 and GND, making sure its at the same voltage as VDD (+supply voltage).
