I want to turn on/blink 16 LED's, so I am using a bidirectional Multiplexer. The choice of which of 16 outputs is controlled by a 4 bit word sent to pins on the MUX. And an Enable which goes low, to send 5 V to the LED chosen. The results are not correct. I have hooked up a 4 X switch, to the MUX, and it works correctly. I am noting also, that the 2 second delay is > 2 sec.
Any ideas? Thanks in advance.
Multiplexer,16->1 or 1->16, Not working, MEGA_2560_R3
Billduck1302
- Has thanked: 2 times
- Been thanked: 1 time
- PinTest for 120 seconds_V1_One_MUX_Second_Try.fcfx
- (18.08 KiB) Downloaded 173 times
