DSP component output selection for I2C. Advise Please.
canary_wharfe
Has thanked: 6 times
Been thanked: 12 times
Post by canary_wharfe »
Which component DSP Output should be used on the flowcode panel to prepare the output for sending out of a PIC's I2C hardware to an I2C outboard DAC. I need a DSP output icon on the flowcode panel (to finish off the DSP processing), then I plan to read the integer value from that output into a variable and then transmit the value of that variable on the I2C pins to the ext. DAC. When I look at the options available it looks like the correct component is the Output Digital [2D] but rather than guess I'd rather check from someone more knowledgeable.
It looks like the Output DAC [2D] component is for PICs with onboard DACs not for ext. DACS via I2C.
TIA.
Has thanked: 703 times
Been thanked: 768 times
Re: DSP component output selection for I2C. Advise Please.
The Output Digital should be what you are after, since it sets a variable with the DSP result.
The variable can then be used to control PWM (as in the case of the example), I2C, SPI, internal and external DAC etc.
There is an example of a frequency generator here
canary_wharfe
Once again Martin. Many thanks for the feedback :-)
