Tutorial to create components with FC10?
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Flowcode v10 Tutorial to create components with FC10?
Post by Xbiotec »
hello,
Do you have a tutorial to create components with FC10?
Seb
Has thanked: 800 times
Been thanked: 866 times
Re: Tutorial to create components with FC10?
Hello Seb,
There is some information here on the wiki.
If you need further help let me know.
Is the component you would like to create for the general public or to remain private?
Xbiotec
Post by Xbiotec »
Thx Martin,
I have different components to create. Some could be public and some private.
I will let you know.
How to create new MCU and update MCU?
Seb
Hello Seb
Xbiotec wrote: ↑
Fri Jan 31, 2025 11:26 pm
Make sure Flowcode is closed.
Copy and paste in windows explorer
%ProgramData%\MatrixTSL\FlowcodeV10\FCD
Then select the directory that is for the type of MCU you would like to add e.g. PIC, ARD, ARM etc.
Open the fcdx file that is nearest to the MCU you want to create.
Save the fcdx in the name of target MUC to be created keeping it within the same directory.
Edit the fcdx for your new MCU.
For the fcdx to take effect, you will need to run Flowcode and select the new MCU you created.
Every time you make changes you will need to reload your project.
Note there won't be any fields within Choose a target e.g Pins , Max MHz etc.
Has thanked: 312 times
Been thanked: 481 times
A while ago, I created the attached worked example for creating a component. You might find this useful too.
Worked example - creating a component.pdf
(1.11 MiB) Downloaded 544 times
Xbiotec
Post by Xbiotec »
Is the Component Source Code IO Expander (MCP23017) on wiki is the last one ?
if not please send me the last version.
thx
Seb
Hello, Seb.
Yes, I can confirm that the MCP23017 source file on the Wiki is the latest version.
alanwms
Has thanked: 27 times
Been thanked: 8 times
Post by alanwms »
Steve-Matrix wrote: ↑
Mon Feb 03, 2025 9:14 am
I always fail with this at step 6. I tried it again today (After giving up months ago) thinking I had incapacity to read but failed again. Maybe I do have reading problems?
I have yet to create a component
If you attach what you have done so far, then I will help you to progress further.
That document could probably be more clear.
In step 6, you "select the rot component" in the dropdown at the top of the "properties" window.
Or is it the step to create the "propType" property that is where the problem is?
