Hello everyone.
When I compile a FC10 project for an ESP32 WROOM, a folder containing the files "build, main, CMakeLists, Makefile, menuconfig, and sdkconfig" is installed on my desktop, instead of installing in the main folder containing the other files; "Flowcode1, Flowcode1.c, Flowcode1.fcfx.001, Flowcode1.h, Flowcode1.msg..."
Can someone help me?
Help for a clean compilation.
djebirmalik
- Has thanked: 1 time
- Been thanked: 1 time
- Has thanked: 697 times
- Been thanked: 767 times
Re: Help for a clean compilation.
The files should be stored withed the default path of
Did you install the toolchain from here?
Also, the path for the default folder should be within File > Global settings... > Location Tab > ESP:
it should also show the default path e.g.
Does your setup look correct when compared to above?
C:\FC_ESP\target nameAlso, the path for the default folder should be within File > Global settings... > Location Tab > ESP:
C:\esp-idfMartin
djebirmalik
Hello; I didn't quite understand how to do it.
I find C:\esp-idf , C:\esp-idf-tools...etc.
Can you tell me the method step by step?
Thanks in advance.
Thanks in advance.
