7 seg display
peterhalloway
Has thanked: 1 time
Flowcode v10 7 seg display
Post by peterhalloway »
So I am playing with my development board. I could not get it to program directly via flowcode but I can at least compile to hex and use a modified pickit2 programming software to successfully program my 16F18877 target. (This does help promote flowcode to hobbyists using a free target).
Anyway on to the actual issue: you can see I have disabled most macros here because I wanted to hone in on the keypad test. It simulates as expected. However, when I program the PIC the 7 seg display is illuminating with digit 8. If I press and hold a key it does display as I would expect but as soon as you let go of the key the 7 seg display reverts back to 8. I do not understand why, can anyone please help?
Pete
<<file deleted>>
Has thanked: 794 times
Been thanked: 858 times
Re: 7 seg display
Hi Pete
The file attached to your post looks like its the .msg.txt and not .fcfx
Can you check your fcfx project and reupload, please.
