Components creation in Version 10
alanwms
- Has thanked: 27 times
- Been thanked: 8 times
I have searched for videos on component creation but only see pre V10 details. Wiki details don't match my V10. Any ideas or links?
- Has thanked: 772 times
- Been thanked: 833 times
Re: Components creation in Version 10
Steve posted a tutorial on component creation here
Can you post your component and and the link to the tutorial then we can advise you further.
Not sure which "text" primitive. Would that be text box or static text - UNDER 2d OR 4d OR Primitives 3d?
- Screenshot 2025-02-09 110624.png (69.64 KiB) Viewed 10576 times
kersing
- Has thanked: 81 times
- Been thanked: 65 times
kersing
Could you describe what issue you are having? Is there something you can not find? Is there something not showing that you need because the text refers to it?
It is hard to help if we have to guess what issue you have.
When a part of a component is exposed e.g. the colour property, then it will show on the Root Component.
To view all exposed properties on the Root Component, you select the dropdown of properties ,then left click on Root Component at the top.
