ATinny85 Sleep Flowcode
Matrixv8
Been thanked: 4 times
Post by Matrixv8 »
Hi everyone, I have been trying to write a code to put ATtiny85 to sleep but with no success. I would really appreciate an example in Flowcode 10. I am using USBtiny as a programmer.
Thank you.
Has thanked: 156 times
Been thanked: 902 times
Re: ATinny85 Sleep Flowcode
Post by mnfisher »
It is possible to do:
In supplementary code:
#include <avr/sleep.h>
Then in a code block:
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Other modes are available - see sleep.h
sleep_enable();
sleep_cpu();
sleep_disable();
You'll also need something to wake up the MCU - for example a pin change interrupt (or wdt interrupt etc)
Matrixv8
Post by Matrixv8 »
Thank you for your help.
Matrixv8
Post by Matrixv8 »
Martin it worked perfectly, the supplementary code was key. Now, I have tried everything to wakeup the ATtiny with INT0 pin7, port B2 with no success. Any idea?
PS: I will keep my questions to a minimum.
Pierre
Post by mnfisher »
Hi Pierre,
Can you post your code.
I'm not at a computer at the moment but something like:
Enable interrupt
Loop
  Sleep
  Do something
End loop
The interrupt macro needs to be short - it doesn't need to do anything (it could be an empty macro) or it could increment a 'wake' counter.
If you are using a rising edge interrupt — the pin needs to be pulled to ground (with a resistor either internal pull-down or external) and if you are using a button watch out for bounce (which might give multiple wakes per press)
Falling edge interrupt needs internal pull up or resistor to VCC
Matrixv8
Post by Matrixv8 »
Hi Martin, thank you for your help. Attached is my Flowcode. I use a 10K pull up resistor on port B2. I use a digital high low output, so no switch noise. I send a high to low pulse. The INT micro works until the chip goes to sleep then I can not wake the chip unless I reset it.
Thank you for you help.
Pierre
Attiny85 Test.fcfx
Feb 25, 20025
(9.96 KiB) Downloaded 126 times
Post by mnfisher »
The 'sleep' is outside of your loop, so it when the MCU 'wakes' it will be just 'fall off the end of the program' - this actually just has a while(1) ; loop - NOT a reset. So move the sleep into the loop and it should work as expected (or add a 'reset' after it?)
I also forgot to mention - if using a separate device for waking then ground must be common.
Matrixv8
Post by Matrixv8 »
Hi Martin, moving the C code in the loop was the first fix to my problem, It would go to sleep but not wake up. I found that the INT0 on Attiny85 with Flowcode 10 was not waking up the micro. I had to use the IOC PortB2 and click on the Port B2 pin 7 of the chip icon inside the Inerrupt command icon for it to work. So both fix created a solution. I am attaching an example for the readers hopping that it will help them as I spent a long time to figure it out.
Again a great thanks for your quick help.
Pierre
Attiny85 Sleep And Wake Up Working Example Code.fcfx
ATtiny85 Sleep And Wake Up Working Example Code
(10.3 KiB) Downloaded 122 times
Post by mnfisher »
Thanks - glad you got it working...
