MCP3008 Analog Expanders
jay_dee
Has thanked: 102 times
Been thanked: 74 times
Post by jay_dee »
This is frankly me just being a bit lazy and I have used these with FC already but a well supported Component for them would be be very handy to many. Unless other good alteratives are already supported.
MCP3008 - SPI, Easy way to add 8x 10bit Analoge channels to your project. MCP3004 is 4 channel and there ar other varients with higher Bit depth.
Things like the Pi PICO are a bit crap for AV inputs.
Nothing urgent from my side but just a thought. J.
Has thanked: 795 times
Been thanked: 858 times
Flowcode v10 Re: MCP3008 Analog Expanders
Hello Thank you for your request.
There are other external ADC component to try.
If you search for ADC then you will see:
ADC Components.png (17.23 KiB) Viewed 4829 times
Some of which will only require two pins as they are I2C driven
However, since you have requested MCP3008, we will create the component for you.
jay_dee
Post by jay_dee »
Hi Martin,
thanks, the MCP offer the 8 channel at 10 bits I think, the others currently supported are 4 channel.
They all kind of do the same thing but some suit certain projects better than others.
thanks, J.
