STM32F dev board programming via DFU USB bootloader
Has thanked: 111 times
Been thanked: 302 times
I found a little time to play with STM32F DFU programming via the USB bootloader, this avoids needing the ST-link programmer.
This has been tested with a WeAct STM32F411CE 8MHz Black Pill dev board.
First install the STM32CubeProgrammer from www.st.com (at default location)
Here's an FCD with modified programming stage 32F411CE_BlackPill.fcdx
to go into directory C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ARM
(46.02 KiB) Downloaded 447 times
And an additional batch program stm32progDFU.bat
to go into directory C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ARM\batch
stm32progDFU.bat.txt
(829 Bytes) Downloaded 473 times
Connect the dev board via USB cable to the PC running Flowcode.
Hold the BOOT0 button and press and release the RST button.
The dev board is now in programming mode.
Compile to Target with Flowcode.
Press RST button to run the newly updated program.
Note to Matrix: feel free to re-distribute these via the repo if you so wish :)
Has thanked: 649 times
Been thanked: 856 times
Re: STM32F dev board programming via DFU USB bootloader
Amazing work thanks Leigh hope all is well.
Those files have now been added in much appreciated :D
abhiak096
Post by abhiak096 »
what if i want to use this method on stm32f407vet6 microcontroller should i do the same , or anything else or is it even possible from flow code to upload code via bootloader method ?
plz help
You could use the output of the Flowcode "Compile to Hex" and use the GUI version of STM32CubeProgrammer.
Your hardware would need to have USB and Boot0 switch implemented.
