WIZ810 Component bug
leoo
Has thanked: 1 time
Post by leoo »
Good day,One of my programmers has pointed the following out to me.Hi Leo,
See below for the bug in the TCPClose function. The problem is the two highlighted instances where 0x401 is used instead of the local variable FCL_CR = 0x401 + (0x100 * FCL_CHANNEL). The result is that socket 0 is always closed, instead of the intended socket.
Michael
Use :When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
:Parameters for macro TCPClose:
: Channel : Specifies the communications channel 0-3
void FCD_01351_TCP_IP_WIZ810MJ1__TCPClose(MX_UINT8 FCL_CHANNEL)
//Local variable definitions
MX_UINT8 FCL_IS_EQUAL = (0x0);
MX_UINT8 FCL_TIMEOUT = (0x64);
MX_UINT16 FCL_IR;
MX_UINT16 FCL_CR;
MX_UINT8 FCL_TEMP;
FCL_CR = 0x401 + (0x100 * FCL_CHANNEL);
FCL_IR = FCL_CR + 1;
while (FCL_IS_EQUAL == 0)
FCL_TEMP = FCD_01351_TCP_IP_WIZ810MJ1__MAC_ReadByte(FCL_IR);
if (FCL_TEMP & 0x10)
FCL_IS_EQUAL = 1;
} else {
FCI_DELAYBYTE_MS(1);
FCL_TIMEOUT = FCL_TIMEOUT - 1;
if (FCL_TIMEOUT == 0)
FCL_IS_EQUAL = 1;
// } else {
if (FCL_TIMEOUT != 0)
FCD_01351_TCP_IP_WIZ810MJ1__MAC_WriteByte(0x401, 0x08);
FCL_IS_EQUAL = 1;
while (FCL_IS_EQUAL)
FCL_IS_EQUAL = FCD_01351_TCP_IP_WIZ810MJ1__MAC_ReadByte(FCL_CR);
FCD_01351_TCP_IP_WIZ810MJ1__MAC_WriteByte(0x401, 0x10);
FCL_IS_EQUAL = 1;
// } else {
}Apologies, but I cannot get the CR to work.
leoo
Has thanked: 1 time
Re: WIZ810 Component bug
Post by leoo »
Good day,
I posted the above a while ago, but it obviously didn't make sense to anybody, hence it being ignored. Below is the symptom that I experience.
I am experiencing a problem when using the WIZ810MJ component, as follows:
After passing data on two open sockets, e.g., socket 0 and socket 1, when closing the non-zero socket (i.e. socket 1, 2, or 3) , socket 0 always closes too, without being told/asked to close. This is experienced in FC7, FC8, and FC10.
It would be appreciated if someone could please comment as to whether this is an issue within the component itself, or whether the problem lies elsewhere.
Kind regards.
Leo
Has thanked: 724 times
Been thanked: 783 times
Hi Leo.
My apologies for the delay.
I have an updated component for you to try,
%ProgramData%\MatrixTSL\FlowcodeV10\Components
Place the attached component.
After testing, can you let me know how you get on.
TCP_IP_EB023_00_2.fcpx
(17.92 KiB) Downloaded 170 times
leoo
Has thanked: 1 time
Post by leoo »
Thank you Martin,
Unfortunately, I will only be able to test on Monday. I will let you know then.
Kind regards.
Leo
leoo
Has thanked: 1 time
Post by leoo »
Hi Martin,
I have tested the new component you sent through and it has rectified the problem as described.
Thank you very much for your assistance.
Kind regards.
Leo
That's brilliant.
Thanks for letting us know.
leoo
Has thanked: 1 time
Post by leoo »
Hi Martin,
I did an update a day or so ago, and I think it included the TCP_IP_EB023_00_2.fcpx component, although I'm not 100% sure.
I am experiencing the same issues, with this new update version, as originally described. I went back to the version you posted on this thread, and it seems to resolve the problems, as per my post above.
Kind regards.
Leo
Hi Leo.
The fixed component should on the database next week , hopefully on Tuesday 22nd.
Until then, if you do an update, Flowcode will revert to the non working version.
