UPDI Programming
Matrixv8
Been thanked: 4 times
UPDI Programming
Post by Matrixv8 »
Hi everyone, I would like to know if Flowcode supports single wire UPDI programming and if so will it work with Attiny1606.
Pierre
Has thanked: 156 times
Been thanked: 902 times
Re: UPDI Programming
Post by mnfisher »
There are two issues here.
First, and most importantly, does flowcode support the target - if not it will need a new fcd file at the least (assuming the current compiler supports it)
Then it needs a way to program the chip - this needs a new batch file to run the programmer (so if avrdude can be used then it will call that using udpi as the programmer)
The actual chip can be connected to a ftdi converter or use an Arduino as a programmer?
