PIC16f1824 ADC set to12 bin should be 10 bit in FG9
baz_w
Post by baz_w »
Hi, How do I change the bit depth of the ADC in a PIC16F1824 to the 10 bit that it is, in FC9 it is set to 12 bit
Has thanked: 724 times
Been thanked: 783 times
Re: PIC16f1824 ADC set to12 bin should be 10 bit in FG9
If you look at the ADC component properties for Bit Depth you should see it's set to 10bit.
I have also check with the ADC PIC CAL and fcd and it looks correct for 10bit.
Can you attach your fcf project and .c files and I will take a look.
Are you referring to simulation, on embedded or both?
baz_w
Post by baz_w »
Hi Files Attached
kNOCK1 3_3_2025.fcfx
(20.45 KiB) Downloaded 105 times
kNOCK1 3_3_2025.c
(49.81 KiB) Downloaded 103 times
