Hello Martin, hello Ben,
anny news about the PIC18F04/05/06/14/15/16Q41 family?
As as already written, it is very urgent for some of my company's
products!
thanks
Dirk
PIC18F15Q41
DirkB
- Has thanked: 1 time
- Been thanked: 4 times
- Has thanked: 709 times
- Been thanked: 773 times
Re: Suggestions for new microcontroller support
Hi Dirk.
UART, PWM and interrupts work well.
There is an issue with I2C so you will need to use I2C in SW mode.
Have you tried using 18F15Q41?
Hello Martin,
yes, but there are 2 error messages. I have used the uart as midiinterface. Is that a problem?
::: error: (1504) the PIC18 extended instruction set was enabled but is not supported by this compiler
(908) exit status = 1
Error returned from [xc8.exe]
And,
I can't compile without midi components. I have extendet cpu disabled!
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_UART.c:585:17: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_UART.c:585:20: error: (182) illegal conversion between types
int -> volatile union S1746
28: error: (255) not a member of the struct/union ""
29: error: (182) illegal conversion between types
volatile union S1770 -> unsigned char
29: error: (181) non-scalar types can't be converted to other types
In the simulation the components work!
Dirk
And,
Dirk
PIC18F15Q41
Hi Dirk, before I will investigate,
Can you Run component updates but change Files in-use to Full database.
Then reload your project and try again.
If you still have an issue then can you attach your project .fcf and . c files.
Hello Martin,
here is my test project. An update has yielded nothing.
Thank you
Dirk
Thank you
Dirk
- Test18F15Q41.h
- (10.11 KiB) Downloaded 384 times
- Test18F15Q41.c
- (48.94 KiB) Downloaded 401 times
- Test18F15Q41.fcfx
- (16.53 KiB) Downloaded 400 times
Hi Dirk.
I have moved some of the latests posts to the general sections as was hijacking Suggestions for new microcontroller support section.
Can you try the attached.
PWM is working for me.
- Test18F15Q41 v2.fcfx
- (17.27 KiB) Downloaded 405 times
Re: PIC18F15Q41
Hi Dirk.
I will See if I can sort this issue on Monday, when I am next at workDirkB wrote: ↑Fri Mar 28, 2025 4:28 pmUnfortunately there is an error message.
Where can I switch it on and off? Where can I switch it on and off? I have not switched it on. And can I expect
the PIC18F04/05/06 - 14/15/16Q41 family to be ready soon?
Dirk
Re: PIC18F15Q41
Hi Dirk.
Configuration setting should now be working well.
The fdcx updates have now been push on to the database and are available to download via Help >Library Updates. Change Files in-use to Full database.
