PIC16F18326 & LIS3DHTR error Help me
seokgi
Has thanked: 8 times
Been thanked: 8 times
Flowcode v10 PIC16F18326 & LIS3DHTR error Help me
Post by seokgi »
I changed the MCU and sensor to complete this project.
MCU: PIC16F18326
Sensor: LIS3DHTR
But it doesn't run.
When I compile the MCU, the following error occurs.
"C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_String.c:1267:: error: (1250) could not find space (256 bytes) for variable _tempSub"
And when I downgrade PIC\PIC_CAL_String.c from version 6 to version 5, it compiles.
And LIS3DTR uses the library (I2C) supported by FC10, but it doesn't work.
Can you show me an example?
I followed the manual for the sensor for SPI, but the SCLK, MOSI, and CS signals work fine, but the MISO data doesn't come out.
Please help me.
Thank you.
Has thanked: 700 times
Been thanked: 768 times
Re: PIC16F18326 & LIS3DHTR error Help me
seokgi wrote:
Mon Mar 31, 2025 1:07 am
Hello, thank you for letting us know about the bug.
That has now been fixed and is available via library updates.
Can you let us know if the issue of MOSI not working still applies after you have updated Flowcode with the components.
seokgi
Post by seokgi »
Thank you.
I will try tomorrow morning.
Thankyou again.
