Disaster!
Has thanked: 839 times
Been thanked: 205 times
Disaster!
Post by jgu1 »
Hi!
I have just working on a project, compile, working all ok, then I discover there was update and I run full update, after update I cannot compile my project anymore? Please help I can´t continue my work, please :shock:
Br Jorgen
NewSunB.msg.txt
(13.62 KiB) Downloaded 139 times
Has thanked: 442 times
Been thanked: 661 times
Re: Disaster!
Hi Jorgen
You can always "roll back" the component(s) / device to a previous version to see if that works.
Re: Disaster!
Post by jgu1 »
Hi Chipfreyer!
Thank´s for reply ;)
Yes I know, and I try to roll all the ESP component back, no succes, and how long back have I to go, don´t know what happen??
Jorgen.
Has thanked: 724 times
Been thanked: 783 times
Re: Disaster!
Hi Jorgen.
I have posted a reply here
Flowcode v10 Re: Disaster!
Post by jgu1 »
Hi Martin!
Thank you. Yesterday I was working on my project, I compile many time, no problem at all, then I discover
There was update availbe, I update full, all and Saw there
was ESP file included, and then I fered, I dare and update restart FC again.
Yes sadly it was now not possible to compile. In that case it have
Somerhing to do with the keypad, I dont need that, I
have worked many hours on my project. How many file do I have to Roll back and what version so I can continue my project. Then I have in the future stop and avoid update, please Martin.
Br jorgen
Re: Disaster!
Sorry for the inconvenience.
No need to roll back just add the ESP_CAL_String.c file that is here
The latest version gLCD display manger is correct.
Let me know if you have any issues.
Re: Disaster!
Post by jgu1 »
Hi Martin!
After overwrite the cal file I can compile again. Many thank´s for your help. I get confused and worry when FC suddenly not work after update :)
Everythig seem to work.
After overwrite the Cal file I try to update again an see there are ESP file and cal file (not uploaded yet) are these som new or is it because I have overwrite?
Br Jorgen
Re: Disaster!
I'm glad you are back up and running.
As soon as the cal is ready for updating, I will let you know.
MJU20
Has thanked: 105 times
Been thanked: 76 times
Re: Disaster!
Post by MJU20 »
This is the main problem with Flowcode..
If there are problems they don't push the solutions.
As soon as there is a problem and a solution, please push the solution at ones.
Now I've spend a evening searching for what I did wrong..
Re: Disaster!
Hi Just let you all know, we have treated this issue with urgency.
There was so much to do it has taken until this evening to sort the cals out and even greatly improved ESP string cal so all the advance string functions are working well.
The updates have now been push on to the database and are available to download via Help >Library Updates. Change Files in-use to Full database.
Can you please let us know how you get on.
