ESP32 Mini not compile!
Has thanked: 811 times
Been thanked: 203 times
Flowcode v10 ESP32 Mini not compile!
Post by jgu1 »
Hi!
Just received my ESP32 Mini and try to compile with a simple testprogram, but not possible. :roll:
Thank´s in advance
Br jorgen
Esp_Mini.msg.txt
(6.34 KiB) Downloaded 121 times
Esp_Mini.c
(1.73 KiB) Downloaded 126 times
Esp_Mini.fcfx
(7.1 KiB) Downloaded 115 times
Has thanked: 700 times
Been thanked: 768 times
Re: ESP32 Mini not compile!
HI Jorgen.
Sorry, this is not going to be an easy quick fix.
Do you still have the original toolchain installed, before we added our own toolchain?
It was using esp-idf-tools-setup-2.3.exe
Post by jgu1 »
Hi Martin!
No I am not sure about the tool chain, it´a while ago I installed, has there been some update I think it was IDF5.xx so I could use all the C and S model do you recommend I try to download the toolchain again from MM and try to install again, and if, should I then uninstall the old first?
The toolchain: ESP toolchain found at "C:\FC_ESP\frameworks\esp-idf-v5.3.1\ Is there a newr?
Jorgen
Sorry, no.
Reinstalling the toolchain won't make any difference.
We are discussing behind the scenes to see what options should work.
What has made more of a challenge is the files that esp-idf-tools-setup-2.3.exe used to download have changed, which has shoved a spanner in the works.
Post by jgu1 »
Well ok Martin, sorry to hear.
If trying to fix this device in FC will affect other devices and it is too difficult and give to many trouble, Martin, then for my sake I can easily live without this device ;)
I only see it as a tiny, rapid unit and fast to use in small project.
Br Jorgen
If you are interested the S3 Mini compiles OK, which is the version that was discussed here
Post by jgu1 »
:lol: Ok for me,I will order a couble, please read my previus answer. Thank you. ;)
