C code to Flow blocks
andeug
Has thanked: 24 times
Been thanked: 2 times
Post by andeug »
I would like to know if the feature of converting existing code to visual blocks exists in Flowcode.
For me, it would be easier to be able to see blocks instead of digging into the code lines.
Andreas
FC11 Professional + ARD + ARM license + Matrix TSL E-blocks2 boards
Mikroe Click boards + Click Shield for ST Nucleo-32 + Clicker 4 for ST STM32F407VG
Has thanked: 264 times
Been thanked: 424 times
Re: C code to Flow blocks
Hopefully this feature is what you require:
https://www.flowcode.co.uk/wiki/index.p ... Conversion
andeug
Post by andeug »
Yes, that's one option. Thank you for the tip. Meanwhile, I discovered a software called Visustin, which does the same but with more supported programming languages.
