Compiler error PIC10F202
celebriums
Has thanked: 25 times
Been thanked: 11 times
Post by celebriums »
Hello everyone
I get a compilation error on the PIC10F202 processor. I compiled the PIC10F, PIC12F series for testing, unfortunately there are compiler errors.
I am sending the error about 10F202 below.
It was fixed when I installed PICCALC string 4 version.
Why is this happening?
Target folder: C:\ElektronikProjeler\Industrial Lightning\BOWIO\Software
Source name:   C:\ElektronikProjeler\Industrial Lightning\BOWIO\Software\10F202D18042025.fcfx
Title:
Description:
Device:        PIC.10F.10F202
Generated by:  Flowcode v10.1.2.40
Date:          Friday, April 18, 2025 14:25:35
Users:         1
Registered to: mehmet64 (99154532)
Licence key: 9P152P
https://www.flowcode.co.uk
Using <PICkit2 PK2CMD External Power> inbuilt settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat  "C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\" 10F202 "C:\ElektronikProjeler\Industrial Lightning\BOWIO\Software\" "10F202D18042025"
C:\ElektronikProjeler\Industrial Lightning\BOWIO\Software>REM CRC: 90CF26913586BBA787FE92D553771933222DCF72B25FEB4608E17FBD060500D8A6D7AF8357042D9E8B5C2E833010A32BE2214988CBC1BB00301ECF6745983589807C95A2F1C2769D70BE3AA931A3F48B38E582CFD8E4085DD8DA408700E5719BB0FE44B686FBBF4050CACCEB0B5A8E521002EAF3D15174CD20633AD186EC562DBEEF6112EA5AA5CF5041CCE14E8D252BC416ECB8EC7761E4FD518969900F56C6C8F36CE7BEFFD91E73F563CBE7F64B8A69F01B3F3C0F45102C3050DA273BE4EE1468065B86E00B2487B7DE8D413948019019AFB8908E26D0AE50ACE3D7DDA2D28E9421B336835453
C:\ElektronikProjeler\Industrial Lightning\BOWIO\Software>REM REVISION: 3.0
C:\ElektronikProjeler\Industrial Lightning\BOWIO\Software>REM GUID: 50CB4B58-ED9C-4591-8D65-A87DE810E8CC
C:\ElektronikProjeler\Industrial Lightning\BOWIO\Software>REM DATE: 09\01\2024
C:\ElektronikProjeler\Industrial Lightning\BOWIO\Software>REM DIR: FCD\PIC\batch\pic_xc8_comp.bat
C:\ElektronikProjeler\Industrial Lightning\BOWIO\Software>"C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\bin\xc8-cc.exe" -mcpu=10F202 "10F202D18042025.c" -w=359,1273,1388 -fno-short-float -fno-short-double -std=c90 -Os
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_String.c:567:: error: (1250) could not find space (24 bytes) for variable _temp_string
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
Autoclose turned off
FINISHED
Sadık Süme
kersing
Has thanked: 79 times
Been thanked: 64 times
Re: Compiler error PIC10F202
Post by kersing »
The controller does not have sufficient RAM memory required for your code. Did you recently add new arrays/strings or components that require a lot of memory?
