STM32 COMPILATION PROBLEM
max.tisc
Been thanked: 12 times
Flowcode v10 STM32 COMPILATION PROBLEM
Post by max.tisc »
HI I made a small code to test the analog inputs on the blackpill board that mounts a STM32F411RET using FC10, but during compilation I have many errors, I replicated the same code on FC9 which compiles correctly and the code on STM32 works correctly, I attach the 2 codes and error report of the FC10
thanks
STM32F411_ANALOG_FC9.fcfx
(20.11 KiB) Downloaded 168 times
STM32F411_ANALOG_FC10.msg.txt
(33.27 KiB) Downloaded 162 times
STM32F411_ANALOG_FC10.fcfx
(22.44 KiB) Downloaded 157 times
Has thanked: 724 times
Been thanked: 783 times
Re: STM32 COMPILATION PROBLEM
Can you please, see the fix posted here
The fix won't be required when a new revision is added to the component database.
I will let you know when that has happened.
max.tisc
Post by max.tisc »
OK done, thanks
The fixed file is now on the component database.
You can now update to the correct version by changing Files in-use to Full database.
This time don't have Show up-to-date files enabled.
After updating the component, you will need to reload your project.
