After last update everything broke
TheShadowOfTriumph
Flowcode v10 After last update everything broke
Post by TheShadowOfTriumph »
For example, test project.
On working project i got 50 screens of errors.
testing.fcfx
(8.91 KiB) Downloaded 172 times
Has thanked: 698 times
Been thanked: 768 times
Re: After last update everything broke
Can you please, see the fix posted here
The fix won't be required when a new revision is added to the component database.
I will let you know when that has happened.
The fixed file is now on the component database.
You can now update to the correct version by changing Files in-use to Full database.
This time don't have Show up-to-date files enabled.
After updating the component, you will need to reload your project.
TheShadowOfTriumph
Now PWM works normal!
