'Exclude From Build' options for build error debug
Brendan
Has thanked: 64 times
Been thanked: 17 times
Post by Brendan »
Quite often it can be somewhat frustrating getting to the bottom of build errors, whether they be embedded in macros, conflicts in var types, interrupts, etc.
It's certainly possible to copy the project to a new file, deleting macros and variables (etc) until a successful exploratory build points at the problem, though would be nice to be able to simply right-click macros and select 'Exclude from build', as though they weren't there (for build purposes) but remaining available for reinstatement within the project. Naturally, validation must still apply, in the same way that it would if attempting to delete macros and variables with existing dependencies for example.
I believe such feature might save a lot of time to debug some problem projects.
Just a thought - Don't ask me "why" :)
All the best,
Brendan
Has thanked: 258 times
Been thanked: 413 times
Re: 'Exclude From Build' options for build error debug
Thanks for the suggestion. I have added it to my list.
Brendan
Post by Brendan »
Thank you Steve - Entirely appreciated.
jay_dee
Has thanked: 99 times
Been thanked: 68 times
Post by jay_dee »
Any tool that helps with de-bugging are always great additions.
Has thanked: 154 times
Been thanked: 883 times
Post by mnfisher »
In a way, you can mimic this using a global constant let's call DEBUG and then in each macro have a code block at the start with
#ifdef DEBUG
And sat the end of the macro
#endif
The problem might be that the macro will call other macros - dsi knocking out one actually might mean a while chain of macros are not compiled.
I would also suggest looking at a form of 'test driven development' - test that each function compiles (and for the full TDD effect runs passing appropriate tests) before creating another test etc -there is a book called Test Driven Development for microcontrollers on this.
Making small macros (functions) with no side effects that perform a single function of key.
