PWM Woes
alanwms
Has thanked: 26 times
Been thanked: 8 times
PWM Woes
Post by alanwms »
Attempting to do a small test with PWM on FC10 with PIC12f1840. I can't get a scope signal on the PWM using simulator. Any ideas? See attached test
Has thanked: 755 times
Been thanked: 819 times
Re: PWM Woes
Hi Alan.
It looks like the attachment has not been added.
alanwms
Re: PWM Woes
Post by alanwms »
I don't know how to attach anymore?
alanwms
Re: PWM Woes
Post by alanwms »
Here it is
PWM CODE.fcfx
(9.96 KiB) Downloaded 412 times
Has thanked: 468 times
Been thanked: 697 times
Re: PWM Woes
In your component properties you forgot to assign your PWM timer.
Once assigned (in this case timer 2) you can then base your duty cycle on your Period value. You have chosen 1000Hz which FC calculates out as Prescaler = 64 and Period = 77 for your oscillator values (external, 20MHz).
I usually set this in the chart too.
You can then figure out your values to give 0-100% cycles based on your PIC capabilities.
alanwms
Re: PWM Woes
Post by alanwms »
I tried that a few times. Currently I have tmr2 assigned. but the simulated scope shows a dead line. Pic chip is 12f1840
alanwms
Re: PWM Woes
Post by alanwms »
Scope meaning the simulated scope in FC
Re: PWM Woes
I have no access to hardware at present but the component gave the correct responses to my test values when simulating. If I get time later I'll look at "scope", but did you set it on the correct pin?
alanwms
Re: PWM Woes
Post by alanwms »
I have no hardware at this time. I'm simply attempting to assure operation using the scope component so I can verify theoretical output. I may hook up the chip for test if I can't get the simulation scope to play.
I assigned multiple pins to the scope thinking that the incorrect pin was allocated - no luck. All four traces dead. No pins worked for me. I am pretty sure I'm not setting something in FC?
Re: PWM Woes
many thanks for letting us know.
I can replicate the issue.
I will look into this and see if I can set it sorted.
