Timer
rufusfeline
- Been thanked: 1 time
Timer
Is there a timer component in Flowcode v6? If so, how to access it and if not, can I download it? Thank you!
- Has thanked: 778 times
- Been thanked: 839 times
Re: Timer
hello.
I have moved your topic from bugs to a more appropriate area of the forums.
No not like v10.
There are only the standard timer interrupts available.
Do you need help setting up a timer interrupt?
If you do, then set up a new flowchart project, setting it to the correct clock frequency and do a one sec flash timer to check hardware is working as expected.
Then attach your project.
As Flowcode v6 is no longer supported, we can't create new components for it.
No not like v10.
