Hi!
I want to startup a new project with ESP32-S2 (improved ACD). If I choose the device ESP32-S2 in device list, and if I reopen to check the device, it jump (Higlight) to ESP32-S2-WROOM all the time. Ad if I look in target device it is the WROOM.
I it on purpose?
Thank´s in advance
Br Jorgen
ESP32 S2
- Has thanked: 724 times
- Been thanked: 783 times
Re: ESP32 S2
It looks like ESP32-S2 has the wrong name WROOM.
Many thanks for letting us know.
However it looks like the ESP32-S2 and ESP32-S2-WROOM have identical FCD's
I don't believe there will be any issue caused by Device Name not being correct.
I have corrected the name.
If you browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
Replace the original file with the attached version.
If Flowcode is already open, then you will need to reload your project.
If you run any component updates, then the fcdx you added will be overwritten.
%ProgramData%\MatrixTSL\FlowcodeV10\FCD\ESP\If Flowcode is already open, then you will need to reload your project.
- ESP32-S2.fcdx
- (49.2 KiB) Downloaded 162 times
