AHT20 humidity sensor reading
OderlandoRSilva
- Has thanked: 4 times
- Been thanked: 6 times
Hello. I would like to know if the AHT10 humidity sensor library can be used to read an AHT20 sensor. If not, is there any expectation in the future of including this sensor in the FlowCode library?
- Has thanked: 163 times
- Been thanked: 960 times
Re: AHT20 humidity sensor reading
It should work as is..
See also https://flowcode.co.uk/forums/viewtopic.php?t=3127 -not yet a component but will read the AHT20 and 21, and if you use the code from the second post the Ens160 too
