Read and write an array to the microcontroller EEPROM
Carmelo
Has thanked: 57 times
Been thanked: 4 times
Post by Carmelo »
I have a variable set as an array of 10 elements and I would like to read and write all the data of that array into EEprom memory.
Can it be done in some way or do you have to read and write them cyclically, one by one each element of the array in a memory location?
C.
Has thanked: 800 times
Been thanked: 866 times
Re: Read and write an array to the microcontroller EEPROM
You can use a loop and increment the count of the loop the count will be the address and send one element at a time as the data value.'
I can post a simple example if you like?
Just don't keep writing as there is a limit to how many times EEPROM can be written to.
Carmelo
Post by Carmelo »
Muchas gracias por la respuesta.
Agradecía el ejemplo.
C.
liudeqiang_2008
Has thanked: 11 times
Been thanked: 2 times
Post by liudeqiang_2008 »
medelec35 wrote: ↑
Fri May 30, 2025 7:25 pm
Could you please post a simple example? I am now have the same question.
Many thanks!
Best regards
Deqiang
