Hello!
I am trying to control the brightness/contrast of the SH1106_SPI OLED display, after searching the internet found out it is possible by using below commands, can someone suggest how to implement the same in chart if it is possible.
display.SH1106_command(0x81);
display.SH1106_data(50);
Thank you.
Abhi
OLED SH1106_SPI Contrast
Abhijit
- Has thanked: 15 times
- Has thanked: 442 times
- Been thanked: 661 times
Re: OLED SH1106_SPI Contrast
Hi Abhi
I could be totally wrong here but it looks like you just need to send an SPI command to write to location 0x81 a value of 50.
However if you are using a FC component it might be trickier, but you could perhaps download the source code from the WiKi.
Maybe make a feature request as it seems a handy thing to be able to do?
Hi! Chipfryer
Thank you for your inputs, as said I tried to explore the source code file from WiKi, unfortunately, nothing I understood, probably not my cup of tea.
By the way there is one macro available in the component macro list "Write Command" but again clueless about how to write. I tried to write the same macro 2 times, one with 0x81 and following 50 (I tried several numbers from 1 to 250) but did not notice anything happening, or may be I am not writing it in the correct way.
I hope matrix team may point out some suggestion or correct way to control the brightness/contras.
I am using below OLED for my project.
https://www.waveshare.com/wiki/1.3inch_OLED_(B)
Thank you.
Abhi
Thank you.
Abhi
Hi! Martin
Good morning
Okay, I shall wait for your feedback.
Thank you.
Abhi
Good morning
Thank you.
Abhi
- Has thanked: 724 times
- Been thanked: 783 times
I have added contrast adjustment, but it's untested if you would like to test it for me?
To try the new component feature, browse to this location using file explorer , it's hidden by default so just paste the link into your address bar.
Place the attached component.
After adding component and reloading, can you let me know if the contrast function is working OK on both simulation and hardware?
%ProgramData%\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new component to work
- gLCD_SH1106_SPI.fcpx
- (16.76 KiB) Downloaded 143 times
If the attachment above does not work,
can you then try this attachment and let me know which works more as expected.
- (16.8 KiB) Downloaded 137 times
For anyone using the I2C version.
Attach is a component to try.
- gLCD_SH1106_I2C.fcpx
- (16.09 KiB) Downloaded 131 times
Hi! Martin
good evening
First of all many thanks for taking time to solve the puzzle, following your instruction i replaced both the component files one by one and tried, for the first file nothing worked in chart as well hardware after using the second file contras worked in the simulation but not in the hardware, on contrary i noticed one change in the display which is not normal, i could see one standing line a small one in the left top corner which was not there earlier, i also noticed one change in the properties, one of the fonts "Character Spacing" and "Space Width" do not show the drop down menu, i doubt if that corner line is because of that.
I again copy paste the old component file and everything resumed as before.
Do let me know if you want me to take the trials with some special instructions, i shall follow.
Thank you again for taking time.
Abhi
good evening
Abhi
