Copile Error
ELECTRONICA67
Has thanked: 31 times
Been thanked: 9 times
Flowcode v10 Copile Error
Post by ELECTRONICA67 »
Flowcode 10 has just been updated. I created a simple program that turns an LED on and off, but when I compile the flowchart, I get an error.
Enrique
Last edited by ELECTRONICA67 on Tue Jun 24, 2025 5:34 am, edited 2 times in total.
ELECTRONICA67
Flowcode v10 Re: Copile Error
this is the flowchart. . .
ELECTRONICA67
Re: Copile Error
10HZ.fcfx
(9.14 KiB) Downloaded 183 times
Has thanked: 724 times
Been thanked: 783 times
Re: Copile Error
Hello, thank you for the report, this has been reported earlier today and has now been fixed.
Can you do a full component database update, then reload your project.
ELECTRONICA67
Re: Copile Error
Ok, thank you Martin, has been fixed
ELECTRONICA67
Ok, thank You Martin, has been fixed :)
ELECTRONICA67
Hi Martin,
Do you know if this message only appears on my computer :?: . . .Or if it appears to some users :?:
After applying the patch published in this post, fixed the first message I posted; I updated two computers. Then, I started seeing other messages that I'd never seen before in flowcharts that were compiled without errors or messages. My question is, are these errors in the Flowcode files :?:
And does it affect the operation of the compiled program :?:
P.D. Another observation is that on two other computers that I didn't update with the patch, these messages don't appear; they compile correctly.
(I think there were two patches in the last few days.) I'm compiling programs that were compiled without errors or messages from weeks ago.
I republished the post here because I think the messages are related to this topic.
Enrique
Has thanked: 616 times
Been thanked: 814 times
Re: Copile Error
Hi Enrique,
That warning is because you are using functions or delays as part of your main program loop and also as part of an interrupt. All that it's saying is that it will make two copies of the functions so that there isn't a clash or corruption during runtime.
