Quick question on ESP32 pin selections
- canary_wharfe
- Has thanked: 15 times
- Been thanked: 16 times
Having trawled info from the web I gather that when Wi-Fi is enabled on ESP32 the ADC2 pins should not be used. I believe GPIO 0, 2, 15 are strapping pins and cannot be used freely but I'm not sure about the other pins on ADC2. Does the general advice mean they should never be used in any shape or form when Wi-Fi is activated or is it that they shouldn't be used as analog inputs? Would appreciate some clarification from anyone more knowledgeable on the subject. TIA.
< The Flowcode 11 Pro Silicon Chipper >
- Has thanked: 159 times
- Been thanked: 943 times
Re: Quick question on ESP32 pin selections
It seems to depend on the esp32 model.
Generally it looks as though ADC readings will be either wrong (or blocked) but digital I/O should be okay. Newer variants seem to have less conflicts.
If the WiFi (and Bluetooth) is disabled then they are available for use . I think, favour ADC1 in the first instance.
As mentioned before - test with a serial monitor and helpful messages may be given (unless you've modified the config file)
- canary_wharfe
Thanks Martin. That's what I thought would be the situation. Digital I/O generally ok.
- canary_wharfe
At the moment using the Wemos LoLin 32 lite (or to be exact it will be a clone module as Wemos don't mfr it any longer)
