Hi Leigh,
I have tried to make an FCD file and copied that into both the default and MatrixTSL FCD folders but was not successful in compiling it. I also copied the HAL drivers and xxx.ld files generated by cubemxIDE, but was still not successful..not even close !. Hex compile returned a "you are not licensed..." error.
Since I am working on a low-power project and getting this chip working on FC-10 will be of great help.
Attaching here the FCD file (STM32L412KB) and some more that I made if it can be of any help.
Thanks in advance
RTJ Nair
Note: Have commented out certain functions that I don't need for the project. Used a Nucleo-32-L412KB board for xxx.ioc, linker xxx.ld, HAL etc.
Support for STM32L412KB
RTJNair
- STM32L412KBUX_FLASH.ld.txt
- (5.3 KiB) Downloaded 233 times
- Nucleo32_L412KB.ioc.txt
- (8.16 KiB) Downloaded 249 times
- 32L412KB.fcdx
- (41.56 KiB) Downloaded 277 times
- Has thanked: 110 times
- Been thanked: 302 times
Re: Support for STM32L412KB
As you have found, to support a new processor family takes quite some time and effort. Unfortunately I currently don't have enough free time to play with this. The L series is maybe something for Matrix to consider
