PIC32 USB CDC Error
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Flowcode v10 PIC32 USB CDC Error
Post by SpeedPIC32 »
another error has occurred with the USB interface.
Unfortunately, this is an old error that has occurred several times before. Old projects are once again not being compiled.
last discussed in Dec 2020
after that it still worked.
can the last update be to blame?
greetings SpeedPic32
SpeedPIC32
Re: PIC32 USB CDC Error
The file CAL\PIC32BIT\PIC32BIT_CAL_USB_Serial.c doesn't work at all! Version 2
Missing ;
After that more errors...
Seems to be a badly copied and modiefied version of PIC16BIT_CAL_USB_Serial.c ? At least it says so in the description part of the file.
ragards
SpeedPIC32
Please check USB CDC
no longer works since the last update.
I can't even get the original examples like " ADC 9 Click BEN_1 " which I have freshly loaded here to work.
Would be nice if someone could test this.
Thank you very much
SpeedPIC32
Target folder: C:\Users\Uwe\Documents\Matrix
Source name: C:\Users\Uwe\Documents\Matrix\USB_CDC_Test .fcfx
Title:
Description:
Device: PIC32.32MZ.32MZ2048EFH144
Generated by: Flowcode v10.1.2.40
Date: Wednesday, July 30, 2025 16:43:29
Users: 1
Registriert für: SpeedPIC32 (24146314)
Lizenzschlüssel:ZQ34CT
https://www.flowcode.co.uk
Using <cdcICD4> user settings for compiler
Start des Compilers...
C:\Program Files (x86)\Flowcode\Compilers\pic32\batch\PIC32compCDC.bat "32MZ2048EFH144" "C:\Users\Uwe\Documents\Matrix\" "USB_CDC_Test " "32MZ"
Project USB_CDC_Test
Device 32MZ2048EFH144
Objects USB_CDC_Test _32MZ2048EFH144
C:\Users\Uwe\Documents\Matrix>xc32-gcc -mprocessor=32MZ2048EFH144 -DMX_USBHS -IC:\Users\Uwe\Documents\Matrix\. -IC:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 -o "USB_CDC_Test _32MZ2048EFH144\USB_CDC_Test .o" "USB_CDC_Test .c" -DMX_USBHS
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\includes.c:1923:0,
from C:\Users\Uwe\Documents\Matrix\USB_CDC_Test .h:304,
from USB_CDC_Test .c:20:
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\PIC32BIT_CAL_USB_Serial.c: In function 'FC_CAL_USB_Serial_Initialise_1':
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\PIC32BIT_CAL_USB_Serial.c:111:3: error: expected ';' before 'while'
while(appData.deviceHandle == -1 && FCL_DELAY_COUNTER < MX_USB_SERIAL_ENUM_TOUT_X)
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\PIC32BIT_CAL_USB_Serial.c: In function 'FC_CAL_USB_Serial_ReadByte_1':
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\PIC32BIT_CAL_USB_Serial.c:217:9: error: 'FCR_RETVAL' undeclared (first use in this function)
FCR_RETVAL = MX_USBSer_RxBuffer[MX_USBSer_RxPtr++];
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\PIC32BIT_CAL_USB_Serial.c:217:9: note: each undeclared identifier is reported only once for each function it appears in
In file included from C:\Users\Uwe\Documents\Matrix\USB_CDC_Test .h:87:0,
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\PIC32BIT_CAL_USB_Serial.c: At top level:
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\PIC32BIT_CAL_USB_Serial.c:284:24: error: conflicting types for 'FC_CAL_USB_Serial_ReadString_1'
CALFUNCTION(MX_UINT16, FC_CAL_USB_Serial_ReadString_, (MX_CHAR *FCR_RETVAL, MX_UINT16 FCRsz_RETVAL, MX_UINT8 timeout_ms, MX_UINT8 FCL_LENGTH))
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\internals.c:75:26: note: in definition of macro 'CAL_APD'
#define CAL_APD(a, b) a##b
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\includes.c:1915:44: note: in expansion of macro 'CAL_APPEND'
#define CALFUNCTION(type, name, args) type CAL_APPEND(name, MX_USB_SERIAL_NUM) args
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC32BIT\PIC32BIT_CAL_USB_Serial.c:284:1: note: in expansion of macro 'CALFUNCTION'
In file included from USB_CDC_Test .c:20:0:
C:\Users\Uwe\Documents\Matrix\USB_CDC_Test .h:160:6: note: previous declaration of 'FC_CAL_USB_Serial_ReadString_1' was here
void FC_CAL_USB_Serial_ReadString_1(MX_CHAR *FCR_RETVAL, MX_UINT16 FCRsz_RETVAL, MX_UINT8 FCL_TIMEOUT_MS, MX_UINT8 FCL_LENGTH);
Error(s) in build
C:\Program Files (x86)\Flowcode\Compilers\pic32\batch\PIC32compCDC.bat Hat den Fehlercode 0x1 gemeldet
Autoclose turned off
BEENDET
Has thanked: 755 times
Been thanked: 817 times
Many thanks for reporting the errors.
It is being looked into.
Can you upload you Flowcode fcfx project file.
SpeedPIC32
C_Test .fcfx
(32.48 KiB) Downloaded 269 times
SpeedPIC32
I wanted to ask if anything has been found yet?
are there any instructions on what is required for it to work.
for example.
1. project name must not contain a blank character
2. project must be saved in the matrix folder
3. the setup of the paths etc
greetings SpeedPIC32
SpeedPIC32
I have tried it with a PIC18F2550, it works fine
18F2550USB.fcfx
(8.95 KiB) Downloaded 203 times
Has thanked: 245 times
Been thanked: 256 times
Hallo SpeedPic32
Good that it works. Which board did you use?
This one?
Mikroe:
https://www.digikey.ch/de/products/deta ... wBhAF0BfIA
