Error/Warning in the compilation
Carmelo
Has thanked: 57 times
Been thanked: 4 times
Post by Carmelo »
Hola,
During compilation the following warning appears:
T1_4.c:
5589: #warning "This interrupt has previously been enabled, so the macro <INT_TMR0_Tiempo> may never get called."
^ (162) #warning: "This interrupt has previously been enabled, so the macro <INT_TMR0_Tiempo> may never get called." (warning)
using updated 32-bit floating-point libraries; improved accuracy might increase code size
But the compilation ends without errors
What could this warning be due to?
I am attaching the complete compilation message file along with the project.
T1_4.msg.txt
Warning
(3.19 KiB) Downloaded 126 times
T1_4.fcfx
Project
(132.36 KiB) Downloaded 138 times
Has thanked: 434 times
Been thanked: 651 times
Re: Error/Warning in the compilation
It is usually OK to ignore those warnings as it is just informing you that the interrupt has previously been used elsewhere and therefore you may not get expected results.
Carmelo
Post by Carmelo »
OK,
muchas gracias por tan pronta respuesta.
C.
