Clocking up to 252Mhz not possible
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Flowcode v10 Clocking up to 252Mhz not possible
Post by SpeedPIC32 »
can the lock be set from 200Mhz to 252?
for the PIC32MZ2048EFH types
Please check USB CDC
no longer works since the last update
thanks
Has thanked: 795 times
Been thanked: 858 times
Re: Clocking up to 252Mhz not possible
Hello. I have updated the 32M devices to 252MHz as I can confirm that value is within the datasheet.
I have asked for the fcd's to be pushed to the database.
As soon as they are, you will then be able to update to the latest version.
SpeedPIC32
Runs
Many thanks for this
Greetings SpeedPic32
You're welcome.
They should be available now.
