I've just been poking around the microchip website and saw Dual Core dsPICs.
I strongly suspect this would get me very tied up in knots but has anyone tried this sort of product?
I'm going to stick with a std dsPIC for now, but I like the idea of having one device that can run the general houskeeping and another that can be doing the higher speed realtime stuff or just running a CAN engine etc.. I wondoer how they share resources like hardware pins and Can they read/write to the same memory or at least share information?
J.
Dual Core dsPICs - anyone tried these?
jay_dee
- Has thanked: 99 times
- Been thanked: 68 times
- Has thanked: 429 times
- Been thanked: 647 times
Re: Dual Core dsPICs - anyone tried these?
Never used thr dsPIC but a while back with Leighm's help I did get a RPi Pico running Dual Core. Much as you describe above, one core running x, the other y. I believe the ESP32 can do so too but never tried as I find it difflcult enough to get one doing anything let alone on a different core.
The Pico was quite simple to get running and you just used another User Maco for that core.
Edit
This link explains how to do on a Pico viewtopic.php?p=12436&hilit=pico+core#p12436
Edit
- Has thanked: 156 times
- Been thanked: 902 times
On the esp32 it is easy to do - using xTaskCreatePinnedToCore to assign tasks to a specific core.
On the dsPic - it looks like you would need to use the 'core' directive to the compiler
for example:
void __attribute__((core(1))) slave_core_task(void) would run slave_core_task on core_1
The easiest way to (try to) do this in FC would be to use supplementary code - and define for example:
Then call slave_core_task(); from a code block....
Don't have anything to test this theory on though
for example:
void __attribute__((core(1))) slave_core_task(void) {
FCM_Core1_Task();
}Don't have anything to test this theory on though
