ESP32 UART-USB Brige How to use
Has thanked: 245 times
Been thanked: 256 times
Hi to All
I use a Atom S3 with a display. It's working nice with an extern AD converter and shows the values on display.
But I can not send the values to the App-developper
I found a help in the internet, there is an intern UART-USB Brige.
How can I use it?
Select UART0.
Enter the default pins of the ESP32-S3:
TX → GPIO43
RX → GPIO44
Even if you do not wire the pins, Flowcode will know which UART it refers to, and the output will be correctly transmitted to the PC via the USB-CDC port
Uart port:
Testprogram:
Post-ESP32_S3_Display2_MCP.fcfx
(64.11 KiB) Downloaded 473 times
Has thanked: 749 times
Been thanked: 809 times
Re: ESP32 UART-USB Brige How to use
Hi Stefan.
Have you looked at all the PC developer projects here.
There are projects that use USB for communicating between hardware and PC developer using USB
Hi Martin
Yes, right now again. If the board has a UART to USB bridge (for example, CH340C), it works very well.
I have already done many projects with it, and that work very well with the Appdevelopper.
Now the problem:
Many new supermini boards with ESP32-C3, ESP32-C6, ESP32-S3 no longer have an additional IC (UART-USB bridge) on the board.
However, Flowcode does not yet support a direct USB connection for the ESP32.
There is another option for the small ESP-S3 chip.
The ESP32 S3, which has a UART-USB bridge integrated into the chip, as I understand it.
It can be used with uart0 and set TX/RX on GPIO 43 and GPIO 44.
I just don't know exactly how that works with Flowcode.
Hi Martin
I am not yet able to establish a connection between the ESP32-S3 and the PC.
However, I have more information on this.
https://github.com/espressif/esp-usb-bridge
Has thanked: 173 times
Been thanked: 989 times
Post by mnfisher »
I'll have a look- it should be possible using the OTG USB interface...
Post by mnfisher »
Hi Stefan,
Can you try this - run idf.py menuconfig
component config - esp system settings - channel for console output -> Set this to USBSerial/JTAG Controller
NB - target must be set as an esp32s3 (idf.py set-target esp32s3)
Check if usual debug is then sent to USB (using PuTTY for exanple)
Then try using a UART on Pins 19 and 20
I don't have an s3 to test :-(
Hi Martin
I understand there are two ways to use USB: as very fast USB OTG and with the built-in bridge.
I have tried both, but without success.
I'll take a closer look at it.
The ESP32 S3 can be easily programmed with Flowcode.
I will use the small, inexpensive Seed and the Atom S3 display.
I have made a list of various manufacturers if you want an S3.
There are many other ESP32 S3 modules that are very practical.
Seed:
https://www.digikey.ch/de/products/deta ... 4/19285530
Adafruit small:
https://www.digikey.ch/de/products/deta ... 6/21283802
Adafruit comfortable:
https://www.digikey.ch/de/products/deta ... 7/16583982
Sparkfun comfortable:
https://www.digikey.ch/de/products/deta ... 3JyAF0AvkA
From M5 Stack:
https://shop.m5stack.com/
Post by mnfisher »
I tried the TinyUSB component too - but couldn't get it to compile :-( (5.5 or 5.4)
Seemed to be an issue with downloading it - will have a look at the examples too.
Post by mnfisher »
Hi Stefan,
I got a esp32-s3 board and tried this....
If I open a UART and try to write - I get
Leaving...
Hard resetting via RTS pin...
Executing action: monitor
Running idf_monitor in directory D:\Projects\Flowcode\Flowcode1
Executing "C:\Espressif\python_env\idf5.4_py3.12_env\Scripts\python.exe C:\Espressif\frameworks\esp-idf-v5.4.1\tools/idf_monitor.py -p COM5 -b 921600 --toolchain-prefix xtensa-esp32s3-elf- --target esp32s3 --revision 0 D:\Projects\Flowcode\Flowcode1\build\Flowcode1.elf --force-color -m 'C:\Espressif\python_env\idf5.4_py3.12_env\Scripts\python.exe' 'C:\Espressif\frameworks\esp-idf-v5.4.1\tools\idf.py' '-p' 'COM5' '-b' '921600'"...
--- Warning: GDB cannot open serial ports accessed as COMx
--- Using \\.\COM5 instead...
--- esp-idf-monitor 1.7.0 on \\.\COM5 921600
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0x23 (DOWNLOAD(USB/UART0))
Saved PC:0x40041a79
--- 0x40041a79: ets_delay_us in ROM
waiting for download
--- Error: ClearCommError failed (Permiss
However - if I use printf (so I used printf("Hello world\r\n"); in a code block) then I get output sent to the USB port..
On initial connection - I had to press and hold boot and press and release reset to get Windows to recognise the device.
On 'locking' the device - I find reset does the trick - although after attempting to open UART (channel 2) I need to 'boot + reset' again.
I'm using 'idf.py -p COMn -b 921600 flash monitor' to upload and 'run' my chart. (Where n = 5 for me)
Have you had any more success?
Post by mnfisher »
Testing again - using UART channel 1 (and default pins!) - I get Hello World output to USB - this still from printf(); - nothing from SendString() :-(
There are a couple of (extra) blank lines between them - but otherwise - running okay (rather than 'crashing' as before)
