hi all,
ive recently acquired some pic 16f18446 chips and using flowcode9 im able to generate a hex file for my project however when using pickit 3 it seems this programmer does not support this chip ive also a mikroelektronika programmer but this too does not support this chip. could any one point me in the direction of a suitable programmer please
cheers
programming a pic 16f18446
siliconchip
- Has thanked: 6 times
- Has thanked: 156 times
- Been thanked: 902 times
Re: programming a pic 16f18446
It looks like the PICKit3 should be compatible - see section 39 in the datasheet.
Is your PICKit firmware up to date - and how do you have it wired to the MCU?
Also it might be worth trying PICKitPlus software (see PICKitPlus.co.uk) - again the specific chip you have is listed in their documentation as compatible.
siliconchip
hi ive tried to find firmware forthe pickit with no joy, ive got the kit plugged into a zif plug this has always worked well with other chips but when looking through the libary in the pickit software programmer there seems to be a lot of chips missing
