Direct Write to easypic7
hiromiyureei
Been thanked: 5 times
Flowcode v10 Direct Write to easypic7
Post by hiromiyureei »
Good morning, I tried "write directly to the micro" with a Pickit 3 and 4 and it works, but I'd like it to be possible to write directly to an EasyPic 7 or 8, this one for example.
https://www.mikroe.com/easypic-v7?srslt ... riGzeLruMa
Thank you very much.
Has thanked: 800 times
Been thanked: 866 times
Re: Direct Write to easypic7
I have not got easy pic myself, so I can't verify the correct commands.
You must install the mikroProg Suite and the easypic7 drivers
Run Flowcode and select the target device from Build > project options.
Open Build > Compiler Options and click on the floppy disk icon and enter a name e.g Easypic7, select OK.
Select The new Easypic7 option, select the Programmer Tab.
Within Location browse to the mikroProg Suite exe.
e.g.
C:\Program Files\Mikroelektronika\mikroProg Suite For PIC\mikroProg Suite for PIC.exe
Within parameters enter the following:
-e -w -pPIC$(chip) -v -f"$(outdir)$(target).hex" -q
Make sure the Default compiler for the platform C for PIC is ticked before selecting OK
-v is verify and open an OK prompt.
To speed up the programming the -v can be removed
If you don't want the suit to quit, then the -q can also be removed
I have added the information to the wiki.
hiromiyureei
Flowcode v10 Re: Direct Write to easypic7
Wow, it works perfectly and can be used with settings -e -w -pPIC$(chip) -f"$(outdir)$(target).hex"
This simple solution is very comfortable.
Thank you very much :D :mrgreen:
You're welcome.
Thank you for updating us.
I'm glad it works for you.
