Raspberry Pi HDMI example
RGV250
Has thanked: 41 times
Been thanked: 42 times
Post by RGV250 »
After having a lot of grief with the Raspberry Pi HDMI component and getting a lot of help from people on the forum I thought I would post an example so you do not have some of the issues I had. It is not complete as I am still trying to figure out some things but hopefully it will give you a good start.
RaspberryPi_HDMI_Test_1.fcfx
(31.78 KiB) Downloaded 161 times
Bob
Has thanked: 696 times
Been thanked: 767 times
Re: Raspberry Pi HDMI example
Hi Bob.
Thank you for your example.
Have you read the Raspberry getting started guide?
RGV250
Post by RGV250 »
Hi Martin,
I had read that doc when I had FC9.
There are a couple of typo's, I assume it is meant for FC10 now but it mentions FC8 near the start.
Also it says using a 3B+ and then all the images show 3B.
Not a big issue but thought I would mention it.
One thing I did notice where it says Debug message capability directly from the Raspberry Pi to a console window on the PC, I thought Debug was only available for Pro users.
Bob
