Help project will not open
wayne_millard
Has thanked: 1 time
Been thanked: 9 times
Post by wayne_millard »
Hi Flowcode
I have a project that i have been working on and it will not open now.
Can you please see if you can fix it.
Flowcode2.fcsx
(109.54 KiB) Downloaded 648 times
Wayne M :oops:
Has thanked: 163 times
Been thanked: 960 times
Re: Help project will not open
Post by mnfisher »
Try -
wm.fcsx
(95.14 KiB) Downloaded 661 times
Not sure what had gone awry - it would open in FC8 -- resaved and then reloaded in v9. Something odd though - it's quite a bit smaller file?
Note that FC makes a backup (file.01) which can sometimes save your bacon...
wayne_millard
Has thanked: 1 time
Hi Martin
Thanks for that I did not think you could open in a older package. I have had a look and I have files called .001 and they will not open.
This is strange.
Wayne M
Post by mnfisher »
Might need to rename the 01 file (delete the .01)
Would be good to have 'git' integration in FC - although it does work with manual updates...
Interested to know if anything was 'missing' from the recovered file?
Has thanked: 234 times
Been thanked: 252 times
Hi Wayne
Can you post your error message?
I also had an error and when I open your program it is the same error
https://flowcode.co.uk/forums/viewtopic.php?f=9&t=326
wayne_millard
Has thanked: 1 time
Hi Stefan,
Yes it is the same error message.
Wayne
Has thanked: 616 times
Been thanked: 814 times
Hello Wayne,
Here is the fixed file please let us know if it happens again.
Flowcode2.fcsx
(109.54 KiB) Downloaded 790 times
