I hadn't noticed before that flowcode offers the option to use an emulated EEPROM. That's quite interesting.
STMicroelectronics says it's possible to create an EEPROM on STM32F0 microcontrollers by applying AN4061 notes, but I'm not sure if this is possible in flowcode.
The Flash EEPROM component doesn't seem to work on this microcontroller. Or am I doing something wrong?
Is it possible to use the "Flash EEPROM" component on the STM32F030F4P6?
OderlandoRSilva
- Has thanked: 4 times
- Been thanked: 6 times
- Captura de tela 2025-09-02 063901.png (31.55 KiB) Viewed 2514 times
- Has thanked: 637 times
- Been thanked: 847 times
Re: Is it possible to use the "Flash EEPROM" component on the STM32F030F4P6?
The current component won't work with the STARM devices no but I have used the flash on an ST ARM device as EEPROM and so I'll dig out the code and see if it's possible to add into the current component.
OderlandoRSilva
Hello, Ben. All right. I appreciate your dedication. Thank you very much.
