Re FC_Comp_Source_RedditNewsHeadlines.fcfx
Amtor
Has thanked: 21 times
Been thanked: 16 times
Post by Amtor »
I happened to come across this source code on on the wiki page, but I can see it as a component anywhere.
Sorry if this has been asked about before, I did have a search but didn't find much.
Why is it not saved as a component I wonder.
Mark
Second try, think I attached the wrong file last time
(24.64 KiB) Downloaded 392 times
Has thanked: 478 times
Been thanked: 713 times
Re: Re FC_Comp_Source_RedditNewsHeadlines.fcfx
Just guessing that it may have been deprecated, and was intended as an example to interact. I see though that in searching components there is no entry for Reddit News but there is for BBC News. Principle of operation most likely the same.
Amtor
Post by Amtor »
Thanks for the reply
The BBC News component used to work really nicely, but it stopped one day and I could never make it work again. The BBC Weather component though works fine. I just thought I might try that one to see if it had any life in it. But I don’t think my latest license is valid to turn it into a component though.
Mark
Has thanked: 795 times
Been thanked: 858 times
The component did not work correctly, so it was left.
Because there was a source file, it automatically was available via the Wikki.
The problem with writing any component that interacts with 3rd-party servers, such as News / Weather etc is that you are at the mercy of the service provider. What works today may not work tomorow as they have changed something.
Personally, I found the examples to be helpful in learning how to use the components to interact. I think there is a "hello world" example somewhere that interacts with a server held by Matrix, so it works well (or used to). From that example it lead to me writing code to interact with all sorts of services.
