AS5600!
Has thanked: 912 times
Been thanked: 222 times
Flowcode v10 AS5600!
Post by jgu1 »
Hi all!
It´s a while I last used this component so a need a test.
I am trying to make a project where I need some kind servomotor, for an automatic gate opener. So I have bougth a couble of AS5600 hall angle sensor and will first test these device with FC.
After make a test setup and managed to fix the small magnet on a shaft and center the PCB over the hall sensor ( have to be stabil and close ) I try create a testprogram, yes it work so nice with FC10 as well in debug as in realworld :D
I try to change the in the Properties for analog and PWM out, can change it, perfect.
I also try to change the Slow and fast filter and Hysteres, but I don´t see or feel any change, Properly me ;)
Anyway the AS5600 with Flowcode is perfect, so hereby, share my little testprogam maybe usefull if anybody need a diy servomotor or measure an angel.
Again one of MM team´s very well working component macro (Benj) :D
https://www.ebay.com/itm/233616919644?_ ... R5D47PasZg
Fas5600.fcfx
(13.45 KiB) Downloaded 335 times
Has thanked: 799 times
Been thanked: 863 times
Re: AS5600!
That's great!
I'm glad the component is working well for you
Thanks for sharing Jorgen.
