Analog Pin Configuration for PIC16F84A with Potentiomete
r_teixeir
Has thanked: 2 times
Post by r_teixeir »
Hello everyone,
I'm working on a Flowcode 8 project using the PIC16F84A microcontroller. I noticed that when I try to use a potentiometer as an analog input, there is no option to configure the analog pin mapping for the selected pin.
Is this a limitation of the PIC16F84A within Flowcode, or am I missing a configuration step? Any guidance or workaround would be greatly appreciated.
Thanks in advance for your support!
Best regards,
Rodrigo L.
Pic16F84A_Prog_AN_Leds.fcfx
(10.85 KiB) Downloaded 238 times
Has thanked: 468 times
Been thanked: 697 times
Re: Analog Pin Configuration for PIC16F84A with Potentiomete
As far as I remember, the 16F84A doesn't support ADC function on any pin.
You could use an external ADC or any one of a number of similar PICs that do support ADC.
r_teixeir
Post by r_teixeir »
Thanks though! just checked the datasheet and u're totally right. My mistake
Best regards!
Rod
Im not at a PC just now so can't offhand recommend a direct replacement, but there are many similar PICs that do support ADC.
Has thanked: 633 times
Been thanked: 837 times
I beleive the 16f88 is a pin compatible option with adc ability. There are loads though any 18pin 16f should be pin compatible.
